Sponsored by: Real Truck
PSD problem
Old Dec 23, 2006 | 10:38 PM
fishman002's Avatar
fishman002
PSD problem
I started up my 2000 350 PSD the other day and drove it. I got about a mile down the road and the truck seemd to shut down just for a split second then restart on it's own. When it did, the check engine light illuminated along with the water in fuel light and the wait to start light. At first I thought it was my imagination but it did it 3 more times before I could get it turned around and back home. The next day it started fine, idled for a minute, then did the same thing. It ran a few minutes more then died but restarted imediately. After restart it romped briefly then died. It restrted OK again. I am afraid to take in out of the driveway now. Any thoughts?
Old Dec 23, 2006 | 11:15 PM
6L PWR's Avatar
6L PWR
I don't know much, but I've learned that wierd electrical type of issues usually stem from ground problems. Try cleaning the battery terminals and connectors and try finding the engine block ground connections and cleaning them and check the wires for wear and frays and feel them to see if they feel like they might be broken inside the sheathing. Oh, and good luck.
Old Dec 23, 2006 | 11:19 PM
fiftyfives's Avatar
fiftyfives
check the cam position sensor
Old Dec 24, 2006 | 09:36 AM
ponch37300's Avatar
ponch37300
Sounds like a cps issue, they are well know for failing. Most people keep a spare in the glove box. The best place to get one is ebay, in a ford package for about 60 bucks shipped but i think they are at least double that from the stealership. The parts store brand ones are know to fail also.
Old Dec 24, 2006 | 10:26 AM
DD1684's Avatar
DD1684
If your Water In Fuel Light is coming on you may have a clogged fuel filter, which will make your truck run like crap. I'd change the filter right away and then see how it drives after that. If the filter change doesn't help I'd say change the CPS.
Old Dec 24, 2006 | 05:05 PM
Lou Braun's Avatar
Lou Braun
You might want to post this problem in the 7.3 forum and give one of the experts a shot at it.
Since you are seeing the wait to start, water in fuel and check engine lights all at the same time, it sounds more like an electrical problem causing a computer reset.
Lou Braun
Old Dec 24, 2006 | 05:28 PM
DavidT.'s Avatar
DavidT.
Sounds like your CPS is going bad. The computer uses the CPS signal to fire the injectors. A bad or faulty CPS will confuse the computer and a truck would have the symptoms you are having. When the CPS quits, so does your truck.
Old Dec 24, 2006 | 10:10 PM
fishman002's Avatar
fishman002
CPS is what I was figuring too. I just change all of the filters just before winter so I do not think that is the problem. But...........could it be the fuel pump?
FISHMAN002
Old Dec 25, 2006 | 07:25 PM
Fat Diesel's Avatar
Fat Diesel
Nope. If it's the fuel pump it will start to chug and gasp. A CPS will cut out and cut back in. Go to the 99-03 PSD section and browse until you see a CPS related thread. Lots of info there.
