Sponsored by: Innova
Ported subwoofer
Old Dec 23, 2006 | 08:39 PM
mrwake's Avatar
mrwake
Ported subwoofer
Hey, I bought an 94 square body f-250 and it had a fixed up stereo system Ill get the names of the stuff tomorrow. But it has a 12inch sub behind the seat that has a good kick but it is not ported. What size hole should I put in it? What difference does it make?
Old Dec 24, 2006 | 12:30 AM
elyrain's Avatar
elyrain
if it's not a ported box, it was probably not ment to be ported. Yes, a ported enclosure can net a 3db gain, in a best case scenario. But a ported enclosure usually requires about 50% more cubic volume then sealed.
You should first figure out what sub you have and what type of ported enclosure it would work best in, IE: volume, port with and port length. Before you go cutting holes in your box and making it worse.
