Hello Ed
I'm looking for an Lariat, KR or HD Cluster
I for my 06 FX4 with 5.4 engine
Or something to show how many km's or miles till empty
Thank you
Matt
Ok Matt,
you will need part number
6L3Z-10849-PB CLUSTER Larait from 12/05/05 KM'S list $311.16 FTE $243.10
6L3Z-10D889-AA Switch 4 pin from 12/05/05 list $48.57 FTE $34.97
but you may have to wire it in like the other member on the other forum site had to do and then have the as built info downloaded to make it all work,
whitecrystal's vin is a 05 yours is 06 and looms are different, it's to bad I can't seem to get a vin from a truck/member that has a built date after 12/05/05 that has the cluster(Lariat) and I can compare that vin(loom) to what you have so maybe you would know whether or not you have to wire in the loom to make it work.
I hope I have explained this good enough to understand.
here is my vin for my 07 lariat. Maybe if you look at the part numbers and they haven't changed from 05 -07... you would have some comfort it would work... just and idea.
