Dash Bottom Extension
Old Dec 24, 2006 | 02:41 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Gusso,Thanks for the kind comments. I ordered my dash ext. from mid-fifty, no modifications necessary except to put your own holes in for mounting acc. I used self drilling aluminum screws to mount it directly to bottom of original dash.
I was a little apprehensive about the outboard corners extending into the door openings at first, but now it seems natural to me and causes no problems.
Old Dec 24, 2006 | 03:05 PM
gusso's Avatar
gusso
Wayne - mid-fifty sells a fiberglass and a metal dash extension. I assume yours is metal. Once again, without getting slobberly [word?] thanks for your input and it`s a beautiful, beautiful `56.
Anything else I should know relative to dash extension or installation?
Gusso
Old Dec 24, 2006 | 03:42 PM
B/B ford's Avatar
B/B ford
Clean & Classy
It is the metal one part# 7533. Are you keeping your glove box? I didn,t because I wanted to smooth my dash, and A/C unit took up most of the room anyway. If your keeping a glove box you would probably want to consider one of the other models that are made to accommodate it. I can,t help with those as I am unfamiliar with them.
Wayne
Old Dec 24, 2006 | 04:46 PM
gusso's Avatar
gusso
Wayne - Hi again. I`ve got to keep my glove box. Got a great updated fusebox box in there. Do I understand you correctly- the extension you have will not work or fit when you keep the glove box?
Gusso
Old Dec 24, 2006 | 04:58 PM
B/B ford's Avatar
B/B ford
Clean & Classy
That is my understanding, I would ask mid fifty directly what they recommend. I have seen others that were made to accommodate a glove box.
Old Dec 24, 2006 | 05:50 PM
raerjim's Avatar
raerjim
Wayne showing off that phenomenal truck again...
Old Dec 24, 2006 | 05:57 PM
gusso's Avatar
gusso
Wayne - Thanks for great info! Have a great Holiday
Gusso
steuspeed
Jul 2, 2017 01:23 PM
armyaviation
16
Jan 21, 2017 09:23 PM
sum_weirdo
Aug 18, 2016 08:13 PM
IDIoit
Apr 13, 2016 09:10 AM
Second79F250
Mar 29, 2016 11:37 AM
