won't start well when warm
Old Dec 22, 2006 | 09:40 PM
cookiemonster1312's Avatar
cookiemonster1312
my 1986 f150 302 fi does not want to start when warm. start great when cold. spins over but will not catch unless you pump gas. runs ok when started.
help?
Old Dec 22, 2006 | 11:09 PM
Franklin2's Avatar
Franklin2
Check for black smoke from the tailpipe when it finally starts. You may have some leaky injectors flooding the engine. For your info, holding the gas to the floor while cranking will turn the injectors off completely.
Old Dec 23, 2006 | 01:34 PM
cookiemonster1312
Thanks for info. If the injectors were leaking would't it be hard starting all the time not just when then engine and outside temp. is warm.
