8.8 wheel bearings.
Old Dec 22, 2006 | 01:58 PM
natewoz's Avatar
natewoz
8.8 wheel bearings.
Do I need a slide hammer to pull them, or how do you do it? Thanks
Old Dec 26, 2006 | 04:45 PM
LeoJr's Avatar
LeoJr
Yep, rent a sliding hammer and yank them out. Don't be surprised if one or both are very stuck and the inner comes out, spilling the bearings. Which leaves you with a solid outer race to grab.
Be carefull setting them back in straight. If they start crooked they can be a real challange to seat all the way in.
Old Dec 27, 2006 | 04:21 PM
javi2001's Avatar
javi2001
Remove the roller form bearing and leave the internal race alone, then use a standard electric arc welder to put some heat over the race DON'T touch the axle !!!
When it still very hot, put in some cold water, termic shock will expand the race, then should be free enough to be removed hitting softly over...
Old Dec 27, 2006 | 05:09 PM
LeoJr's Avatar
LeoJr
I'm sure this is the correct technique for a different kind of axle, but for a 8.8 the outer wheel bearing is a complete assembly and is pressed INTO the axle tube...thus the bearing puller that grabs from the inside diameter. The axle removes slides out from the bearing once the C-clip is removed.
javi2001, am I confused?
Old Dec 28, 2006 | 08:37 PM
javi2001's Avatar
javi2001
Nop you are right, my info was about a Dana 44... Thanks for the clarification.
