Locker????
Old Dec 26, 2006 | 07:14 PM
wcurtis's Avatar
wcurtis
Locker????
I have never worked on a rear end of a truck, so I have a question, I want to put limited slip in my 2001 f250 SC long bed 2WD. I was think of going to a junk yard and getting a whole new back axle??? or How hard is it to did in a locker?? or will it be cheaper to just get the axle at a junk yard??
Old Dec 26, 2006 | 09:41 PM
twisted's Avatar
twisted
i myself have never done it but i think you will have to reset the backlash and pinion depth as well as maybe reshim it which you need specail tools for. i could be worng, like i sadi i never did it myself either.
Old Dec 27, 2006 | 07:09 PM
darrin1999's Avatar
darrin1999
if i were you i would invest in the tools to replace the diff yourself, if you can change a rear end you can replace a diff. any truck rear end youd find in a junkyard would have too many miles on it to trust. what id do is go out and get a full rebuild kit for your rear end, replace all the bearings, and then put in a detroit locker. summit part #DTL-225SL56A. all you really need is the patience to pull the diff out a couple times to replace shims when youve checked the clearances and ring gear marking pattern
Old Dec 27, 2006 | 08:29 PM
wcurtis's Avatar
wcurtis
Thanks Guys, I'm going to try it, But I'm going to get some help from one of my Buddy
Old Dec 27, 2006 | 08:40 PM
darrin1999's Avatar
darrin1999
good luck and have fun
Old Dec 28, 2006 | 10:01 PM
bronco521's Avatar
bronco521
check the backlash BEFORE pulling it apart.after putting new diff in,re-set backlash to what it checked before.
