soft/drooping clutch pedal
I have a 89 Superduty with a 460 and 5 speed manual transmission. The engine was replaced along with the clutch last year. The problem I'm having is the clutch pedal doesn't return to the normal height after depressing it. The clutch still works but I have to raise it with my foot under the pedal. Any ideas on what might be causing this. The clutch has new hydraulics and pressure/clutch plates and throwout bearing. Thanks Matt
Clutch kit, 56 dollars (fort wayne clutch)
Slave cylinder, 95 dollars (Advance)
Master cylinder, 60 dollars (Advance)
Hose, 15 dollars (pick n pull)
finding out that all you needed was an $18.49 et of pedals from pick n pull because the bushings wore out in yours and ate the whole aluminum bracket... priceless.
DanielT28
07-09-2014 08:48 PM
nassi
04-22-2014 05:12 PM
jon.smith
01-30-2014 04:30 AM
