Rebuilt 302 idle problem
Old Dec 22, 2006 | 10:08 AM
desertdave35's Avatar
desertdave35
Besides having an overheating problem with this rebuilt 302, I seem to be having a problem with the idle as well. If I start the truck and don't touch the gas pedal it will idle fine right about 750 rpms. When I go to accelerate it and hold it at 2000 rpms for the cam break in it runs smooth as glass, but the minute I let go of the pedal it stalls. If I let loose of the pedal real softly and slowly bring the rpms down and then let go of the pedal it will hunt for a second and then idle back at 750 rpms with a little hunting.
Now I did cut off the muffler and I am only running the 2 cats for an exhaust right now, would that be the cause of the idle problem?
Old Dec 22, 2006 | 10:58 PM
petes79f150's Avatar
petes79f150
I suspect a vaccum problem. Carb or EFI?
Pete
Old Dec 23, 2006 | 06:20 AM
desertdave35
Its an EFI, don't hear any hissing sounds coming from the engine area. If I put a vacuum gauge on the vacuum tree off the intake what kind of readings should I get at idle.
Old Dec 24, 2006 | 05:41 PM
petes79f150
Sorry, been busy. 17 to 22 with a steady needle, warm engine in park or neutral, normal idle. A low steady needle usually indicates intake or carb gasket leak. Timing can also effect vac readings. It sounds like something simple, at least it picks back up and idles, right? With a vaccum leak, the carb's not recieving a vac "signal" and just won't "feed" the motor until vac builds back up and pulls fuel into the plenum.
Another way to tell is with engine running, spray starting fluid around the intake and carb gaskets, and if you've got a leak, the engine idle will go way up. Just a thought, I could be way off, but I prefer to start with the simple things first.
Pete
On edit: Sheesh- it's EFI. Anyway, it could still be an intake or vac line leak.
Old Dec 25, 2006 | 06:18 AM
desertdave35
I knew what you meant
Well if it was an intake or plenum leak I will never know. I had to rip her back apart because I had a dead cylinder in #7. But thanks for the tip!
BigRedWeather
19
Sep 4, 2016 06:56 AM
calfj60
Jul 27, 2016 05:54 PM
bassguy46
1983 - 2012 Ranger & B-Series
Feb 21, 2016 06:59 PM
cajunsuperduty
Oct 28, 2011 03:31 PM
JTD1972
1978 - 1996 Big Bronco
Jun 18, 2003 07:16 PM
