94 460 EFI missing and bucking
Old Dec 22, 2006 | 09:36 AM
Boss300's Avatar
Boss300
I am trying to fix my friends 94 F350 with an EFI 460. The idle is rough and misses every now and then. When you get it to a cruise speed around 30 and up it will randomly cut out for a split second and give a bucking feeling. I have already changed the MAP and TPS sensors and it has brand new wires, plugs and cap/rotor on it. It only does this under light loads and if you floor it it takes off and runs like a scalded dog. Also if you put it in gear and hold the brake it will miss when idling and low throttle but if you push it over about a third of the way down it will run fine. The codes were MAP change and TP change as well as one that said PIP Ckt Failure?
Old Dec 22, 2006 | 01:16 PM
andym's Avatar
andym
Did you adjust the TPS after you installed it? TPS's on V8's need to be adjusted with a voltmeter after you install them.
The PIP circuit failure would explain the miss. It's easier just to swap the whole distributor out. You'll need to set the timing after you do it.
Old Jun 19, 2010 | 09:44 AM
Pet982's Avatar
Pet982
Sorry to dig up a 3.5 year old thread but.... what was the out come to this if you happen to remember?
Our E-350 with the 460 is doing the exact same thing. Just replaced the plugs, wires and fuel filter.
Old Sep 5, 2010 | 09:17 PM
richierich4's Avatar
richierich4
Did you guys ever figure out what the problem was?
Chris Braun
Mar 22, 2016 12:03 PM
vintagequest
Jan 20, 2016 05:02 AM
fenwick
18
Aug 19, 2014 04:23 PM
sgg93
Feb 10, 2014 10:23 AM
Pet982
Sep 13, 2010 09:51 PM
