1987 F150 4.9L EFI rough idle runs rich
Ok so i have had an issue with this motor for a while. I have changed everything from fuel injectors to the regulator and filter. I have checked all the vacuum lines with no leaks, the coil and wires are new as well as plugs, new O2 sensor, checked timing, tested MAP sensor and fuel pressure is around 60 psi while at idle. no Cats as they were stopped up dual pipes running to a thrush dual in/out muffler 2.5 pipe. EGR is not connected. Before we played with the timing it wouldn't start without help from ether and would stumble on idle and just flat out refuse to run without playing with the throttle, but it would cruise fine but would hate going 30 or below it would just start bucking. After we played with the timing it will start and idle better but it misses now cruising with it set around 5-7 BTDC. The engine has around 16000 Miles and was put in in Jan 2010 and it has always burned rich. The ECU died on me about 2 years ago when moisture got into it and the 10MHz crystal rotted off and i repaired it and the truck ran good. We can't figure out where to go from here and i have a trip to Michigan from Tennessee In the 3rd week of April, so if i can get any help it would be greatly appreciated.
Thanks in advance
Chris Braun
Oh, I don't know if this will make any difference, but i'm running a K&N air filter in the air box.
Thanks in advance
Chris Braun
60 PSI of fuel pressure is too high with the engine at idle. ~45 is more typical. I do not see any mention of codes. Did you run the Key On Engine Off (KOEO) tests and stored code display?
Only starting with a shot of fuel or ether leads one to think it's a TPS, ECT or ACT issue. Suggest you checked their values.
When my 93 4.9 would crank but not turn over it was the ecm hat was bad. Two capacitors were leaking, one was completely broken off. Before that it was the tank selector that was broke. Both of these had my truck cranking but would never turn over. Would start when I sprayed carb cleaner In the intake. Then die shortly there after
tscholz2001
15
11-06-2018 02:01 PM
460
1983 - 2012 Ranger & B-Series
16
09-07-2009 07:54 PM
4.9 driver
15
09-06-2007 03:42 AM
