Tightening Dash
Old Dec 21, 2006 | 06:58 PM
93F150/302's Avatar
93F150/302
Tightening Dash
Hello all,
I just bought a 1993 Ford F-150 and I would like to know where the bolts are located to the dash so I can tighten them. Dash seems to move and creek a lot and would like to see if that helps the problem.
Old Dec 21, 2006 | 07:04 PM
quicklook2's Avatar
quicklook2
the passenger side mount is broken.
look right nest to the glovebox and the door.
ford makes a repair kit but it really is just an angle iron screwed into broken piece.
i used epoxy and screen to fix mine.
Old Dec 21, 2006 | 10:02 PM
kell104's Avatar
kell104
I just used epoxy on mine too. The last two trucks of the 92-96 body style have both had the same problem. I still have to re-glue it every other year or so due to temp changes and our perfectly smooth Wisconsin roads. HAHA
Old Dec 21, 2006 | 11:59 PM
Mike Kopstain's Avatar
Mike Kopstain
So that's why it doesn't match up to the A pillar!
Old Dec 22, 2006 | 12:08 AM
kell104's Avatar
kell104
Yeah, I think ford could have tried a little harder on that one. Gets pretty annoying listening to squeek squeek as i go down the road. The rest of the truck is still pretty tight so that one noise really gets to me.
Old Dec 22, 2006 | 05:46 AM
Jeff Dodson's Avatar
Jeff Dodson
Mine makes that noise but it is coming from a very small crack on the outer door skin that goes from the mirror mount to the top, its only about 1 inch long and on the drivers door. The problem is trying to find someone that can weld that thin of metal
Old Dec 22, 2006 | 06:14 AM
tewferford's Avatar
tewferford
I used zip ties on mine. Pulled the right side kick panel off. zip tied it nice and tight. So far its lasted three years.
Old Dec 23, 2006 | 12:00 AM
93F150/302's Avatar
93F150/302
Thanks guys, I'll try working on that this weekend!
