Whats it worth?
Old Dec 21, 2006 | 06:35 PM
El Newbo's Avatar
El Newbo
Whats it worth?
An acquaintance has an 427 FE block and rods. A machinist has looked at the block. Its standard but will need a .010-.030 clean up. Otherwise very nice. Has the cross bolt mains caps. I don't know these engines. I'm just the guy with the internet access. I did not find anything in FAQ. TIA
Old Dec 21, 2006 | 07:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check on ebay.
Old Dec 21, 2006 | 08:35 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well some of us know a little about these engine's..what do you need to know??
RJ
Old Dec 22, 2006 | 05:48 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
And there is a lot of difference between a .010 and .030 cleanup. At .030 over the sideoiler 427 is close to it's natural bore limits. Some top oilers however can go much further and I've heard as much as .060 on some blocks. I was offered a std bore 72 sideoiler service block for $2500. Most I see are in the $2900 range at std bore. Topoilers go for a little less. Around the $2000 for a nice std bore topoiler. You can buy a brand new Genesis or Pond 427 block for around $3300 (plus lots of machine work) that will bring you close to $4000. The rods will either be the large bolt type or the LeMans capscrew style. Those are worth anywhere from $150-350. There are also marine 427 blocks which are cast as sideoilers and drilled as topoilers. So what kind are you looking at??
Jetmx
Oct 15, 2009 10:38 PM
Hussler
Feb 12, 2008 08:29 PM
gappy
Jun 12, 2007 11:33 AM
Ratsmoker
16
Jan 29, 2004 11:29 AM
Broncoguy89
Dec 15, 2003 09:58 PM
