engine
Old Dec 20, 2006 | 08:47 PM
80F250cust's Avatar
80F250cust
engine
hey i need some input on what i should do i did a compression test on my truck and i have a bad piston what should i do. rebuild, find a motor, buy a new one or what gimmie ur thoughts. btw its a 302
Old Dec 20, 2006 | 09:16 PM
wizzard351's Avatar
wizzard351
first of all is it realy a bad piston? mabe its a burnt valve or some thing,if it was me id pull the head and see whats up then repair or pull,if a new engine is needed then go to a local engine builder and geter rebuilt DO not got to oreilys or autozone type thing and get one of those mexican overhauled engine's they just suck a local guy that you can talk to in person and have warrenty will be your best bet
Old Dec 20, 2006 | 11:44 PM
Bdox's Avatar
Bdox
I second that. Pull the head and assess the damage first. If the cylinder wall is gone it's probably toast. But if the cylinder is OK, just rebuild it. As far as replacement engines are concerned, it depends on how the truck is used and how you feel about it.
Old Dec 22, 2006 | 08:11 AM
Duncan10's Avatar
Duncan10
Depends on what you use the truck for or if you just want a beater to get around or whatever. I would get one from a wrecker if you can get cheap enough or do the rebuild yourself. But I agree with the other guys check it out first.
Ki-Adi-Mundi
16
Jan 3, 2015 09:36 AM
Boodrow379
Mar 31, 2013 07:00 PM
tolliewolly
Jul 13, 2010 05:52 AM
Paul.Harrah
Feb 25, 2007 02:02 AM
90 F350 XXL Hotwheel
Missouri Chapter
Apr 2, 2004 02:41 PM
