Sponsored by: Real Truck
maybe it will start
Old Dec 20, 2006 | 07:49 PM
andyk1956's Avatar
andyk1956
maybe it will start
hi working on a 2001 f350 sd 7.3 ps will not start at times hot or cold no codes have replaced cps with ford sensor fuel filter and pump res. are full .monitored icp while cranking with modis went to 16800 psi! is this possible? it started and pressure came down to 4990psi and ran ok untill it was shut off. then didnt restart. help
Old Dec 20, 2006 | 09:50 PM
Pocket's Avatar
Pocket
What are you using to monitor the ICP? Those numbers are waaaaaaaaay off. As a matter of fact, what are you using to read codes? Same scan tool?
Old Dec 21, 2006 | 09:48 PM
andyk1956's Avatar
andyk1956
hi i am using a snap on modis. the reson the numbers were so far off is the scanner was in the metric mode. however the icp does go over 2000psi when cranking and will not start.
