Rear Engine Oil seal leak - common?
Is it considered common to get the odd drop of engine oil leak past the rear engine seal on the 7.3PSD and show weeping out from under the auto trans TC inspecion plate on the bell housing?
Doesn't seem to drop on the garage floor - but theres a drop hanging when I get under there and if you push the plate you see oil weeping out from under it where it joins the bell housing!
It's not ATF - it's clear (yellow) engine oil!
Should I worry at 60,000 miles / 2004 Yr? about a hanging drop?
Previous owner said only problem he ever had was an oil leak (didn't specify where tho).....fixed under warranty!
While the 3 years 60,000 Mile warranty is expired, I have a further 3 year extended warranty, I could claim it under!
Just not sure it's worth worrying about, never seen a ford yet in 30 years didn't leak round the rear graphite rope crank seal!
Cheers!
Cheers!
Cheers!
Cheers!
Good luck!
Yeah, i was about to say to make perfectly sure that it is indeed not coming from the top of the engine, going downward, and dripping off the inspection plate.. Turbo pedestal o-rings when they leak only leak a small annoyingly amount of oil, just enough to coat the back of the engine and transmission in oil but not necessarily enough to puddle on the ground.
So
I'm back to checking the turbo pedestal and rear of engine at top, for source of oil leak huh?
I'll take a looksee and report further!
No rope seal on the crank huh?....well IH did make some good agricultural gear in times past - maybe thats a saving grace!
So....who made the turbo pedestal with the leaky O rings? Garrett? Ford? IH? Jethro Clampett?
Man, I hate oil leaks!
Cheers!
Cheers!
Good Call
It would appear that you've all called it correctly!
While we couldn't detect oil behind the turbo pedestal from the top, (pretty hard to reach in there) the valley of the V8 does have a nice clean pool of yellow engine oil sitting in there which appears to be draining down the back of the engine to the bell housing inspection plate!
I am to assume this is from the Turbo Pedestal O rings gone bad or the High Pressure Oil Pump (wheres that located?)!
I figure since I have a 3yr extended warranty I might as well get it repaired by the dealer eh?
Course - how am II to know for 100% sure of they don't just staem clean the engine and say - there you go....without doing the actual work...
Is there any way to tell with 100% efficacy if in fact the O rings get replaced, or whether I'm just getting a snow job done on me?
Guess I could always ask to see the damaged O rings that are removed!!
So - why do these O rings regularly fail?..any idea's!
Cheers!
Cheers!
How does one know
How does one know if the leak is from HPOP or turbo pedestal O rings?
All I know is oil pools in the valley and drips out the transmission TC cover plate!
Is there any easy way to determine if it's HPOP O rings rather than Turbo Pedestal O rings!
As stated - we tried real hard and got hands around behind Turbo, compressor wheel, and pedestal etc and didn't come up wet with oil (just greasey/dirty with dust and old oil)!
As a last resort, poked finger down thru wiring harnesses on top of valley and came out wet with clean oil... The oils clean coz the trucks only done 1000 km's since it's last service and the sump oils still clean!
I have no manual - and don't know where the HPOP is located...
How hard is a HPOP replace O rings task?...it has to be easier than a turbo pedestal tear down doesn't it?
I've read about some special thin spanner tool and using same from small grinder / dremmel tool...to hold the body...
Whereabouts does one actually see this HPOP and whats it look like - I presume it's somewhere in the valley if the oil pools there?
Just from what I read here, it sounded more like HPOP to me than a Turbo pedestal base O rings leak, but I could well be wrong!!
I would just like to know what to tell the Ford Dealer mechanics to look for when I take it in (and be right about same)!
Cheers!
Cheers!
If you look below the fuel filter housing at the top center of the engine, you will see a wierd looking thing that certainly does NOT look like a pump, that has two hydraulic hoses coming out of the left side. Well at least here on the LH drive trucks, the HPOP has hoses coming out of the left side ( ) and sometimes just tightening the nut will fix it.
Cheers!
Cheers!
Warranty
You guys may get 5 years or 100,000 miles, but downunder we only get 3 years or 100,000 kilometers (60 000 miles) warranty from the Ford dealer!
Mines done 104,000 km's so is outside factory warranty, but I did buy a factory extended warranty, for another 3 years, so they will end up doing it anyway, unless it's something as simple as me tightening a loose nut or something!
I'll have to try and identify this HPOP thing....it's not the black round black plastic flying suacer shaped thing right in the middle is it?
I am spending a fair bit of time with my head under the hood - but it seems i ain't understanding a lot of what I'm seeing just yet!
Believe me it ain't for the want of trying!
I'll take a photo in the morning....
Cheers!
Cheers!
After reading this thread I was checking mine as well, and found a yellow o-ring laying in the rear of the valley pan a little smaller than a quarter. Does anyone know what this would be from? In July the dealer had fixed the exhaust valve linkage because it was leaking, and not sure if the o-ring is from that or something else-Thanks
