C6Te FE heads????
Old Dec 19, 2006 | 10:34 PM
keisha9's Avatar
keisha9
C6Te FE heads????
if anybody has alll the info on these it would be greatly appreciated thanks......c6te heads
Old Dec 20, 2006 | 04:48 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
66 heads used on 352-390-410-428 maybe some others also. 72 +- cc chambers and std size valves.
Old Dec 20, 2006 | 06:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FT or FE?
I don't have a ref handy but that engineering number might pertain to FT heads, off the C/F/L/N600's and larger trucks.
If the valves are sodium with/without rotators, it's a FT head.
Old Dec 20, 2006 | 07:34 AM
keisha9's Avatar
keisha9
thanks guys....what is ft? some one told me these were cj heads . im guessing that they are same as c8ae....any other thoughts or if u have reference. THANKS!
Old Dec 20, 2006 | 08:06 AM
NumberDummy
Someone else will come along with a better ref to those heads...all I know that my 65 has C4AE heads...which I believe the 66's have also.
FT engines were used in C/F500-1000/Big Trucks
Old Dec 20, 2006 | 09:09 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
I'm pretty sure those are FE heads. The FT heads from the 330,361,389 and 391 are easy to spot. The heat crossover is towards the center of the head and matches the intake. Also the FT heads have big chambers and smaller valves. If the crossovers are off center then they are FE heads.
As far as being 428 CJ heads they are not. The CJ heads were late 68 and carry a C80E prefix. There is a C6AE-R lowriser that is called the poor man's CJ head. They are the last of the lowrisers and are cast very close to what the CJ heads were.
See if your heads have a 6090 and a letter also. Ex: C6TE-6090-B. That is a complete casting number more or less. Post what you can find. They could be either B or G heads. Both are pretty much the same anyway.
halltm
15
Jul 18, 2011 04:10 PM
keisha9
Dec 22, 2006 08:02 AM
fordilicious
Nov 2, 2006 11:42 AM
lisagoud
Oct 15, 2004 04:24 PM
Kidd
Sep 6, 2002 12:53 AM
