factory stereo install from probe?
Old Dec 19, 2006 | 09:52 PM
triple150's Avatar
triple150
I have a factory Ford CD deck from a 1997 probe that I had in my 1995 F-150.
Wiring plugged right in to the 95 worked like a charm. Now I am trying to install into my 1994 F-150 but have had no suck luck other than lights coming on the deck.
I ahve pulled the amp. from the 95 F-150 for the wiring and the deck to work together.
Are there any grounds req"d to be hooked up?
Old Dec 20, 2006 | 09:12 AM
subford's Avatar
subford
Yes there are grounds.
Here is a 1994 Premum Sound diagram:
http://i54.photobucket.com/albums/g9...remumSound.gif
Old Dec 20, 2006 | 11:32 AM
lostin90s's Avatar
lostin90s
I did same thing 95 Cd w/amp to 93 Everything pluged in but no lights I had 2 switch wiring but can't remember which one's . It wasn't ground issue though. Good luck
Old Dec 20, 2006 | 05:23 PM
triple150's Avatar
triple150
Lostin90s you had to switch wires where? I don't believe I have power running to the deck only instrument lights. Is it possible the hot wires are different colors from different years?
Any help guys.
Thanks
Old Dec 20, 2006 | 05:27 PM
subford's Avatar
subford
Any help guys.
Thanks
Did you look at the diagram that I posted above?
Old Dec 20, 2006 | 05:32 PM
triple150's Avatar
triple150
yeah I did just printed it off unfortunately I do not have the truck or stereo with me right now. I will diagnose once my ride gets back.
Old Jan 3, 2007 | 10:09 PM
triple150's Avatar
triple150
Subford I am not all that good at vreading wiring diagrams. I could use some coaxing along here. Or if somebody is aware of what wires need to be changed around that would be great.
My understanding is Ford changed the harness but not the color of any wires just locations coming out of the main computer harness.
Old Jan 4, 2007 | 08:00 AM
subford's Avatar
subford
Your problem is that the 1994 & 1995 Plug and amp are completely different.
You will need to pull all of the pins out of C212 on the 94 truck and put them back in the plug using the 95 C212 Plug layout.
Here is a diagram of the 94 & 95 C212 Plugs.
http://i54.photobucket.com/albums/g91/subford/Radio/9495C212SpeakerPlug.gif
If the 1994 did not have an amp then the speaker plug would have looked like the one below.
http://i54.photobucket.com/albums/g91/subford/Radio/94C258SpeakerPlug.gif
Note that it does not have a power wire, ground or logic Mode wire. But this plug should plug into the radio and it should work without the amp.
Old Jan 7, 2007 | 07:36 PM
triple150's Avatar
triple150
This is becoming a pain in my a** OK, I followed the wiring diagrams changed the wires and still nothing! I am going to find another stereo to try out because if this is wiring is correct I have a problem some where else. and all fuses are good. Thanks for all the info subford most appreciated. I hope to close this simple yet trying case soon.
