I have a 1989 Ford 350 E series with a fleetwood tioga motorhome on top. It comes standard with a 22 gallon gas tank and I am presently trying to add a tank or increase the size of the tank. Adding a tank does not seem feasible. I wonder if I can replace standard 22 gallon with a larger tank. It is a behind the rear axle tank. Dimensions are 33 1/2 "x 23 1/2" x 11 1/8". Looks like I could drop down to 15"or16" in the height.
Do they make a replacement tank?
Any response of help would be greatly appreciated. I want to get on the road. If you could even steer me in the right direction it would be great.
Thank You
big steve
Welcome Steve, nice to have you on board here.
That`s a tuff one, have you tried contacting Fleetwood?
You can try Towing, Trailers And 5th Wheels forum for ideas , here is the link: https://www.ford-trucks.com/forums/forum68/
If not try some of the other forums: https://www.ford-trucks.com/forums/index.php
Hopefully sommeone will be able to help.
There is also a aftermarket forum that may be able to help. Click on the forums tab at the upper left and browse over the forums to see what may interest you.
