Gauge Problem
Old Dec 19, 2006 | 06:40 PM
PICCALO358's Avatar
PICCALO358
Gauge Problem
F100-i6-300-auto-swb
Fuel,temp,oil Pressure Gauges All Decide They Want To Read High Periodically,then They Go Back To Normal.already Changed Regulator In Dash,regulator Under Hood And Looked For Loose Connections.any Ideas What To Look For Will Be Appreciated.
Old Dec 20, 2006 | 03:26 PM
Franklin2's Avatar
Franklin2
I would go back to the instrument cluster. Take it apart and clean all the copper traces with a pencil eraser.
It's a long shot, but you might also want to take the ground strap that goes from the engine to the firewall and clean it up.
Old Dec 25, 2006 | 05:14 PM
Mil1ion's Avatar
Mil1ion
Sometimes a firm rap on the dash settles them down to normal..but the cleanup is the best thing to do.
Usually around the ICVR as the corrosion grounds out the circuit causing the gauges to pin.
