Sponsored by: Real Truck
08 F450 ?
Old Dec 19, 2006 | 03:26 PM
sjprice's Avatar
sjprice
08 F450 ?
Is it true that the F450 only comes as a crew cab with Dual Rear Wheels. I was under the impression from the Ford web site it was available as a SRW, but a dealer tells me it is DRW only? Does anyone have any information to the contrary?
Old Dec 19, 2006 | 05:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
From what I have seen on ford.com, it only comes DRW crew cab with a Power Stroke. You choose 2x4 or 4x4, trim package and transmission.
Old Dec 19, 2006 | 09:32 PM
BlueOval5.0's Avatar
BlueOval5.0
I believe this is the case as well.
Old Dec 19, 2006 | 11:16 PM
texan2004's Avatar
texan2004
I thought I saw a single rear wheel version of it on that video they did at the Texas State Fair in Dallas. But I could be mistaken.
Old Dec 19, 2006 | 11:40 PM
blackhat620's Avatar
blackhat620
2008 F450 PU is DRW only. Here is a link to the order guide.
http://www.sunrisefordfleet.com/pdfs...er%20Guide.pdf
Hope this helps
Old Dec 20, 2006 | 12:10 AM
jake00's Avatar
jake00
I'm thinking you could get a chassis / cab in any combo, ut the PU is crew diesel only
Old Dec 20, 2006 | 12:13 AM
Matts72's Avatar
Matts72
I've seen F550s that were SRW... new ones may be different though... so at one time you could get F450/F550s as SRW.
Old Dec 20, 2006 | 12:26 AM
blackhat620
The F450 CC can be had in Regular Cab, Super Cab and Crew Cab configurations, but all are DRW.
Hope this helps
Old Dec 20, 2006 | 12:30 AM
blackhat620
If i remember correctly, F450 & F550 where always DRW from the factory, but some aftermarket companies made them SRW by installing "Super Singles" in place of the DRW.
Old Dec 20, 2006 | 08:16 AM
ccerniglia's Avatar
ccerniglia
www.sunrisefordfleet.com/pdfs/orderguides/2008/2008%20SD%20F450CC%20Order%20Guide.pdf
Hope this helps
A DRW Regular Cab? Can't say i've ever seen one of those.
Old Dec 20, 2006 | 08:19 AM
sjprice's Avatar
sjprice
Thanks to all for the help and answers. Looks like I will be ordering an 08 F350 instead of an F450. The benefits of the DRW does not overide the downside.
Old Dec 20, 2006 | 11:25 AM
blackhat620
You may want to look around at your local Telephone, Electric, Gas and water company service trucks. Majority of there HD service trucks are Regular Cab DRW with a service body installed. Hence the reason Ford and GM have made Standared cab DRW CC trucks for years.
Hope this helps
Old Dec 20, 2006 | 11:31 AM
blackhat620
The benefits of DRW are more stability when towing and a higher GVWR & GCWR. If you don't need the heavier weight rating of a DRW and this truck is going to be more of a daily driver than a dedicated towing vehicle, then yes SRW would be cheaper to purchase, maintain and easier to park. The F450 was brought out for people who need the higher GVWR & GCWR that a Medium duty truck provides for towing their RV's, than what the F350 Light duty truck is rated for.
Hope this helps
Old Dec 20, 2006 | 11:43 AM
redford's Avatar
redford
Don't confuse the F-450 commercial chassis with the F-450 pickup. They are not quite the same thing.
Old Dec 20, 2006 | 03:58 PM
Dragrazor's Avatar
Dragrazor
Any pics or prices on these?
