Exhaust question
Old Dec 19, 2006 | 11:08 AM
jkh04200's Avatar
jkh04200
Exhaust question
95 PSD.
I'm fixing to replace the down pipe with one I bought from DPP. How much can I ecpect from this? Should I remove the cat? I was told this exhaust flows good and I wont see much improvement. I'm looking for economy, performance on this thing is great.
Old Dec 19, 2006 | 12:23 PM
tjbeggs's Avatar
tjbeggs
don't expect huge or even small returns for your investment. it may boost economy a hair. But don't expect it. That way you won't be let down. If you plan to keep the stock exhuast which does flow pretty good except the down pipe then I would gut the cat while you are there and install the downpipe.
Those two together may boost your mileage some.
Old Dec 19, 2006 | 01:26 PM
nojeffgordon's Avatar
nojeffgordon
I know that when I went with the bigger down-pipe, removed the cat and muffler, I lost a little bit of bottom end, but my truck has 3:55's. If I had to do it all over again, I would have gutted the cat and removed the muffler....
