Modular V10 (6.8l)
V10 cylinder numbers HELP???
Old Dec 19, 2006 | 10:37 AM
csharp2a's Avatar
csharp2a
Smile V10 cylinder numbers HELP???
I need to know the cylinder numbers on my V10...
I think that they are 1-5 on passenger side from the front of the truck and 6-10 on the drivers..
Cyl 1 and 6 at the front...
I need to change the COP on Cyl #5.
Thanks,
Craig
Old Dec 19, 2006 | 11:51 AM
FirstTimeFordGuy's Avatar
FirstTimeFordGuy
Those #`s are correct. Good luck with that #5 replacement, I only had to do #2.........
Old Dec 19, 2006 | 11:55 AM
jade97's Avatar
jade97
I got this from an old post:
Numbers 1 thru 5 are the passenger side bank front to rear. 6 thru 10 are the drivers side bank front to rear. Number 6 coil is a can of corn to change...5 minute job at best. The firing order is 1,6,5,10,2,7,3,8,4,9.
Old Dec 19, 2006 | 12:11 PM
dallbright's Avatar
dallbright
...is a can of corn to change...
That's an interesting way to put it...I never heard that expression before!
I like it...
Old Dec 19, 2006 | 12:15 PM
csharp2a's Avatar
csharp2a
Thanks everyone for the responses! I hope that #5 is not too bad...Got to do it tonight...shes running really bad!
Sure sounds like a lot of people have to replace the COP's...is this a pretty common problem?
Old Dec 19, 2006 | 01:14 PM
biz4two's Avatar
biz4two
Arrow
It is a fairly common problem...really depends on age, mileage, and care of V10.
Good luck...
biz
Old Dec 19, 2006 | 02:18 PM
csharp2a's Avatar
csharp2a
Its a 2003 F-250 63000 miles...started missing on a long trip
Old Dec 19, 2006 | 04:02 PM
Big Orn's Avatar
Big Orn
Don't feel too bad - My first COP went about 45K
But, mine is a 4WD and had seen many a muddy road by then.
Usually it's the cheap boots that allow the spark to go to ground - then it causes to COP to go south.
Old Dec 19, 2006 | 04:36 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
When I did my plugs, I put a couple of floor mats on top of the hood latch and surrounding area, put down a big bed comforter or two and just layed right on top of everything.
I weight 225 lbs, have a big belly, and didn't damage a thing.
I used a step ladder to get that far.
Old Dec 20, 2006 | 09:33 AM
Big Orn's Avatar
Big Orn
That's why they're called a "Tool Shed".
Old Dec 21, 2006 | 08:57 AM
benr0's Avatar
benr0
WoW Krewat, Mine held up to the same kind of abuse...
johnno5
6.2L V8
Jan 28, 2017 10:02 AM
Hilt6
Modular V10 (6.8l)
Jul 26, 2016 07:49 PM
jimbo1969
Jul 13, 2016 10:50 PM
Gary Frank
1983 - 2012 Ranger & B-Series
Feb 16, 2014 02:12 PM
Ranger GT2
Dec 16, 2005 03:24 PM
