Fuel Pressure Regulator???
Old Dec 19, 2006 | 10:10 AM
FARM69's Avatar
FARM69
I've discovered yet another fuel leak on my PSD. It is coming out of the what i think is the FPR on the driver side of the fuel filter area. Its round and threads into the the filter housing. On the side that is plastic is the side the wire connects to.
Is this the FPR or something else??
Old Dec 19, 2006 | 06:51 PM
trike1946's Avatar
trike1946
Could be the vacuum switch. Mine leaked too. quick fix.
Old Dec 19, 2006 | 07:41 PM
bkcowboss's Avatar
bkcowboss
The FPR is a metal assembly on the driver side of the filter, it has two JVC hose fittings that screw into it on the side closest to the front of the truck, they are flex hose, and the a metal tube that come up to the bottom of it into a small filter bowl on the driver side there is a 19 mm brass plug, and a vacuum switch with a wire in it. Hope this describes it well enough for recognition. It is mounted to the side of the filter bowl with two 10mm bolts.
Old Dec 19, 2006 | 07:56 PM
FARM69's Avatar
FARM69
Ok, I'm thinking its the vacuum switch. It has a red coated wire going to the metal assembly.
Old Dec 19, 2006 | 07:57 PM
bkcowboss's Avatar
bkcowboss
Yup.............
Old Dec 20, 2006 | 03:03 PM
FARM69's Avatar
FARM69
Anybody have a part # for the vacuum switch? I've been looking around and it doesn't seem to exist???
Old Dec 20, 2006 | 04:16 PM
bkcowboss's Avatar
bkcowboss
best bet is call the stealership get the part # and then try and cross reference it somewhere else.
Old Dec 20, 2006 | 05:15 PM
1997F-350's Avatar
1997F-350
Fuel Filter Restricted sensor; on filter housing 94/95; on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435c1
an easy fix that has been done before it to throw a pipe plug in it.
Old Dec 20, 2006 | 05:32 PM
FARM69's Avatar
FARM69
"an easy fix that has been done before it to throw a pipe plug in it" - Do I need this sensor then?
Thanks for the numbers 97-350. I will have to run on over to the International tomorrow. Hopefully it doesn't cost an arm and a leg
Old Dec 22, 2006 | 09:33 AM
FARM69's Avatar
FARM69
So I just got around to calling International and they only wanted 15$ for this "vacuum switch." I've read on older posts saying it costs anywhere from $52-60 from the stealership. Can there really be that much of a price difference between the two?
Old Dec 22, 2006 | 09:42 AM
bkcowboss's Avatar
bkcowboss
absolutely, just got a CPS from international 150 dollars cheaper than the stealership works great
Old Dec 22, 2006 | 09:54 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Just call your local Ford dealer and ask. But you had better be sitting down.
Old Dec 22, 2006 | 06:00 PM
FARM69's Avatar
FARM69
Its not worth the time to call.. but man... Thats sweet! Thanks for the help guys.
fishmanndotcom
30
Mar 27, 2018 10:30 AM
Trapperpete52
21
Mar 4, 2013 06:35 AM
Spktyr
Jun 13, 2012 08:31 AM
jad4
17
Jul 20, 2009 08:31 AM
firebug
13
Feb 24, 2008 02:54 PM
