Which FE?
Old Dec 19, 2006 | 07:42 AM
scottie2hottie's Avatar
scottie2hottie
Question Which FE?
Help me figure out what FE I have. This is the first FE I have ever owned, and I don't know a whole lot about them. Ok the truck it's in is a 360 2bbl truck per the vin. BUT this motor has a 4bbl, and it appears to be a factory intake. What should I look for?
Old Dec 19, 2006 | 09:48 AM
TKKTommyboy's Avatar
TKKTommyboy
one of these guys will chime in and tell you what to look for but you def. cant rely on the vin# according to my vin i have a 360 2 bbl also but it is actually a 390 with a 4bbl stock intake from a 65 thunderbird....is there still a little aluminium tag on the intake where the coil bolts on? just wondering im sure most of those tags are gone by now but the one i got from the J\Y still had the tag and it says the year of the vehicle and the motor it came from originally....just a thought
Old Dec 19, 2006 | 10:24 AM
scottie2hottie
I know i know i don't have a 2bbl, and thats what the vin says. that's why im asking. Ill look for a tag here in a bit
Old Dec 19, 2006 | 11:08 AM
rusty70f100's Avatar
rusty70f100
It might still be a 360. It really isn't all that hard to swap a 4 barrel on a 360.
I think the easiest way is to check the stroke, assuming no tag.
3.5" = 352 or 360 (most likely 360 since that's what it came with)
3.784" = 390, 406 or 427 (most likely 390 since it's by far the most common)
3.984" = 410, or 428 (you're real lucky if it's 3.984")
Old Dec 21, 2006 | 02:07 PM
Hendricksbus's Avatar
Hendricksbus
I've noticed a diference between the two! my 390 has the oil dipstick in the timing cover and the 360 has it in the oil pan! or I'm mistaken!
Old Dec 21, 2006 | 02:28 PM
dzjammer's Avatar
dzjammer
I think the 4x4 trucks with the rear sump have it in the pan. front sump engines (cars, 2 wd trucks) have it forward. At least mine do.
Old Dec 21, 2006 | 02:38 PM
rusty70f100
Most of 'em have it in the block right by the oil filter adapter.
