Sponsored by: Real Truck
erratic ignition switch
Old Dec 18, 2006 | 11:14 PM
nymo's Avatar
nymo
A couple times over the past week; when I turn the key on my F250 - the starter won't engage. The radio, guages and warning lights fire up, but no starter. If I mess around with the shifter on the column it will eventually turn over the starter. It runs perfect for the next 20 or 30 times.
Is there an adjustment that can be made or is there some kind of limit/safety switch that will be needing replacing?
thanks,
Fred
Old Dec 20, 2006 | 06:19 PM
ReAX's Avatar
ReAX
I haven't had to pull my column apart yet, but my 89 had all of the linkage that ran down to a switch at the base of the column. You can try looking under the dash on top of the column, usually held down by two nuts. If you loosen them, the switch will slid forward and back.
Old Dec 20, 2006 | 06:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
How does it work in "N"?
