How to clean an engine safely?
Old Dec 18, 2006 | 09:39 PM
Hometown Pride's Avatar
Hometown Pride
idunno
1990 F350 4x4 Crew
Old Dec 18, 2006 | 09:55 PM
gring's Avatar
gring
I always clean the engine and all parts in the engine compartment by hand with a rag. If there is oil or grease that is hard to remove, I clean with a solvent like paint thinner. If you spray water in the engine compartment you will clean very few parts.
Old Dec 19, 2006 | 11:37 AM
bigfootford's Avatar
bigfootford
I use a rag and spray brake cleaner. Works great.
Old Dec 19, 2006 | 11:40 AM
I-HATE-THIEVES's Avatar
I-HATE-THIEVES
Simple Green on a warm engine, spray and let sit for a couple of minutes and spray off with water. Then treat rubber hoses with armor all.
Old Dec 19, 2006 | 01:30 PM
beal460's Avatar
beal460
I typically spray (with spray bottle) degreaser on about everything I can hit under the hood, and then rinse with water. Done at the car wash you have the option of high pressure which does take the grease and oil off quicker, but the only drawback I have found (being new to Fords) is that extra care should be taken around the distibutor to avoid getting it wet. After I have rinsed everything, Auto Magic makes a product called Super Dress-It, which is sprayed on. After the motor has run for awhile, the Super Dress It sticks like glue and keeps everything very glossy.
The only other problem I have had doing this, is on Chevy trucks where the windshield wiper motor does not like getting wet.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
