Sponsored by: Kumho
hard brake pedal
Old Dec 18, 2006 | 08:26 PM
ak001's Avatar
ak001
hard brake pedal
2000 E350 7.3L Van:
Today I went to stop for a red light and found out that the pedal was rock hard, no indication in previous stops. After missing the car in front of me and finally getting it stopped in the grass with the E brake, it left me with the question what the .... ? I shut off the van and when I started it back up the pedal was back to normal (slightly more spongy). Any suggestions on were to start? I was thinking of brake booster, if this is it, how involved is this job?
Old Dec 18, 2006 | 09:59 PM
WarWagon's Avatar
WarWagon
Sounds like the booster. The only problem is that it seem like an intermitent problem. I would replace the booster and master cylinder. Most auto parts stores will not warranty the booster unless you replace the master cylinder also. Not a bad idea, really. Not too bad of a job, just make sure you follow the instructions and bench bleed the master. Install it and bleed the system and go to town and celebrate. I would say it's about an hour and a half job, including lunch. Have fun.
Old Dec 19, 2006 | 01:46 PM
tjc transport's Avatar
tjc transport
i ain't rite
before wasting your money on a booster, do a vacuum test. it sounds like your vacuum pump is going bad.
Old Dec 19, 2006 | 02:58 PM
rebocardo's Avatar
rebocardo
Considering you have a diesel I agree 100% with TJC as you really shouldn't need a booster so soon on a 6 year old vehicle.
Old Dec 26, 2006 | 01:30 PM
FutureFordOwner8's Avatar
FutureFordOwner8
I had the same problem when I was working on an old Jeep of mine. I found a vacuum leak, plugged it up, and the brakes worked normally after that.
Funke1
Apr 6, 2014 07:28 PM
evan250
Jun 21, 2005 11:52 AM
stagehawk
Aug 18, 2004 11:44 AM
