cannot remove key from ignition switch
Old Dec 20, 2006 | 01:37 PM
gring's Avatar
gring
I was not able to post the photo as my account does not permit attachments. But you seem to have understood my description. I think it did not buzz before. I will go outside and test that. Thank you.
Old Dec 20, 2006 | 02:11 PM
gring's Avatar
gring
You were right. There is no buzzer when the door is open and the key is in the switch. Probably disconnected by previous owner. I removed the steering wheel cover to see if I can reconnect it. But there is only the connection for the horn. To reconnect it, probably I would have to remove the steering wheel. But it is too cold outside. I will do that next summer. All is Ok now. Thank you.
Old Dec 20, 2006 | 02:18 PM
quicklook2's Avatar
quicklook2
you are lucky it didn't short out.
have a good holiday.
Old Dec 21, 2006 | 09:07 AM
Scndsin's Avatar
Scndsin
I ran across that pig-tale when doing a clock spring repair that initally brought me to FTE (Thnx FTE I'm going supporter for Xmas). The original spring contact was taped and tucked away behind the clock spring in the housing and to the right of the center bolt is a square hole and inside of it is an obviously broken off square pot-metal shaft.
At the time of the repair, "Life" intruded and I had to button it up and go TKB...
I've also had the glut of strange Key behavior like pulling out the key while running. Pulling the key out when off with it not lined up with thumb tabs, Results with key not going back in without serious finageling, And key not releasing lock. Goes for weeks with out probs then has a spate of 'em. Its parked now to keep from biting me in the behind.
So yes I know it needs the switch, but my main question is that broken shaft. I got my ford parts counter guy (An actual good, regular guy) to print out an exploded veiw. And he pulled out the two# parts called out , & neither came close to being what you would expect. One plastic, One metal,but no square shape. Difference supposedly being Tilt/Non-Tilt. Mine is tilt.
Is this the dreaded shaft break thats often written about or different? I thought that one was lower
And nope, key in lock buzzer dosent work.
Merry Christmas Y'all
Old Dec 21, 2006 | 09:23 AM
kell104's Avatar
kell104
Question
Does anybody know if can have the tunblers changed to match my old key so I don't end up with a bunch of keys for this thing. If so where, locksmith or dealer? I kind of liked having 1 key.
Old Dec 21, 2006 | 09:37 AM
quicklook2's Avatar
quicklook2
not every locksmith does it but call around until you find one that can.
when i bought my truck key was broken off in switch.
i took it to an auto locksmith and it was like 35 bucks for the new switch and 2 keys that matched the door.
Old Dec 21, 2006 | 09:41 AM
kell104's Avatar
kell104
Thanks quicklook2. I will call around after the holidays.
