gauge installation
Old Dec 18, 2006 | 07:08 PM
96powerstroke's Avatar
96powerstroke
gauge installation
do you guys have you gauges set up so that when you pull the **** to turn on the lights the lights of the gauges come on as well? where do you tie into to do this?
Old Dec 18, 2006 | 07:17 PM
bkcowboss's Avatar
bkcowboss
There is a dimmer wire coming out of the back of your light switch, what I did was stick my test light on each of the pins while it was connected until I found the wire the dimmed up and down via the switch, then spliced my wires in there. Quick and easy. If I can get to it I will look under and tell which wire but right now things are crazy.
Old Dec 18, 2006 | 07:19 PM
bkcowboss's Avatar
bkcowboss
I spliced my wire in 4 inches or so from the switch with a butt connector, 2 wires in one side, on in the other.
Old Dec 18, 2006 | 07:56 PM
ckal704's Avatar
ckal704
You can also enter the circuit at the fuse box with a fuse-tap.
I am sorry i can't remember which fuse it is (10 or 17 maybe?) but if you do a search here for gauge installation, the fuse to use is noted several different times.
Old Dec 18, 2006 | 09:18 PM
1997F-350's Avatar
1997F-350
ok boss, buy some fuse taps.
tap the power for the lights to all gauges into the # 10 fuse and the power for the pyrometer into the #17. the lights come on this way and also work with the dimmer. but use these instructions to help you out
Old Dec 19, 2006 | 08:39 PM
bkcowboss's Avatar
bkcowboss
great link, thanks for the redirect.
Old Jan 4, 2007 | 10:17 PM
rclark1's Avatar
rclark1
Check this page , it tells where to hook up at the fuse box
http://www.smokyvalley.com/gauge_install.htm
