1989 5 speed
Old Dec 18, 2006 | 06:14 PM
tradecki's Avatar
tradecki
1989 5 speed
I am swapping the 5.0 for a 5.8 and would like to know if the 5 speed that i have will bolt up to the 5.8
Old Dec 18, 2006 | 06:15 PM
andym's Avatar
andym
Yes, it will work fine, but I wouldn't abuse it too much.
Old Dec 18, 2006 | 06:24 PM
tradecki's Avatar
tradecki
why is it weak?
Old Dec 18, 2006 | 06:32 PM
andym's Avatar
andym
Yes, it was never put behind a 351 for that reason. Hard to say how long it will last - could make it to the end of the driveway, might go 200k.
Old Dec 18, 2006 | 08:44 PM
tradecki's Avatar
tradecki
will a 5 speed out of a f250 bolt up in my f150 with a 5.8 engine swap
Old Dec 19, 2006 | 08:46 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes, so long as the F250 five speed is mated to the 300 six or the 5.8. You'll need a driveshaft from an F250 (with the same wheelbase as your F150) if your truck is two wheel drive.
Old Dec 19, 2006 | 12:33 PM
big smith's Avatar
big smith
That 5-speed is a mazda built M5OD. This was was used in the bronco 2, all explorer, ranger and f-150(except 5.8l) with manual transmission. The 5-speed from a f-250-350 would be a ZF transmission. The M50D will be fine, as long as it is working resonably to begin with, and you don't ask the world of it!
Old Dec 19, 2006 | 02:04 PM
preppypyro's Avatar
preppypyro
So if a 5 speed manual is behind a 5.8 from the factory, it is a zf, and not a M5OD? So that means a zf would bolt up to a 302?
Old Dec 19, 2006 | 02:10 PM
andym's Avatar
andym
You are correct.
Old Dec 19, 2006 | 02:11 PM
preppypyro's Avatar
preppypyro
That is sweet to know, thanks
Old Dec 19, 2006 | 03:51 PM
tradecki's Avatar
tradecki
thanks for the help
Old Dec 19, 2006 | 03:54 PM
MustangGT221's Avatar
MustangGT221
Correction...
"That 5-speed is a mazda built M5OD. This was was used in the bronco 2, all explorer, ranger and f-150(except 5.8l) with manual transmission. The 5-speed from a f-250-350 would be a ZF transmission. The M50D will be fine, as long as it is working resonably to begin with, and you don't ask the world of it!"
There were TWO Mazda trannies...the M5OD is also known as the M5R2. The M5R2 was in the F-150s. There was a lighter duty M5R1 that was in the rangers and bronco II's. They are two slightly different transmissions, the F-150 version is obviously stronger.
Also, the 302 will bolt up to a ZF but the ZF has different gear ratios. The ZF and 302 were never bolted together from the factory, and the likely reason is because the 302 doesn't have the low end tq to comfortably pull the wide gears on the ZF. The M5OD's gears are closer so it can work better with the 302's more narrow tq band.
FYI, the M5OD is rated for 330ft-lbs of input torque. The 351 was rated for 310tq output. The M5OD will handle a 351...but it wasn't within Ford's variance. Typically, all drivetrain components of this generation are about 30% stronger than necessary (for obvious reasons) and the M5 just didn't fit the bill, even though it'll take it.
If you have an M5 and it's in good standing order, a 351 will work with it, I've done it. I swapped the M5 and ZF from my old F-250 and my present F-150 and drove the M5/351 combo for about 15,000mi and beat the bag out of it.
I can't say it'll last forever but it'll work. And I still wouldn't be towing a whole heck of a lot with an M5 equipped truck.
Old Dec 19, 2006 | 04:25 PM
tradecki's Avatar
tradecki
I am having my 351 built and it will have about 400hp which 5 speed will be the best for me.
Old Dec 19, 2006 | 04:48 PM
andym's Avatar
andym
Then you're going to grenade the tranny the first time you get on it. You need to get the ZF.
Old Dec 20, 2006 | 05:39 PM
MustangGT221
Yup, 400 would definitely pull the pin on that grenade. Small block ZF out of an F-250 or F-350 is the only easy option.
