92 f150 front end
Old Dec 18, 2006 | 12:21 PM
pcc's Avatar
pcc
92 f150 front end
My 1992 2wd f-150 has a whole lot of slack in the steering. I had the ball joints replaced about 4 years ago so i dont think that is the problem but i cant seem to figure out the problem. Also sometimes i can hear a knocking sound from under the drivers side floorboard....sometimes even feel it on my feet. Any advice would be appreciated. Thanks in advance. phil
Old Dec 18, 2006 | 01:10 PM
Conanski's Avatar
Conanski
You need to do an extensive inspection of all steering components including the shaft between the wheel and box, looking for worn parts. Also inspect the frame on the passenger side near the firewall, dripping moisture from the AC evaporator is know to rot the frame rail and cause it to break. Worn suspension bushings on the TTB mounting points will also cause excessive movement and clunking.
Old Dec 18, 2006 | 01:18 PM
pcc's Avatar
pcc
Thanks Paul. The truck has 258,000 miles on it (dad bought it new). Would changing my steering box be something worth considering or should i put a stabilizer on it??
Old Dec 18, 2006 | 01:30 PM
Conanski's Avatar
Conanski
If the steering box is the source of the excessive play then it would be wise to change it. Do not overlook the tie rod joints and the U joint in the steering shaft, a little play in each of these can add up to a lot overall.
Old Dec 18, 2006 | 03:56 PM
andym's Avatar
andym
A steering stabilizer is band-aid for a broken steering system. Fix the real problem and you won't need a stabilizer.
Old Dec 19, 2006 | 09:53 AM
pcc's Avatar
pcc
Thanks guys. I'll keep my finding posted. phil
