power problem
Old Dec 18, 2006 | 09:14 AM
feepe's Avatar
feepe
power problem
I have a 2005 f-350 6.0 liter that has not been run for at least 5 months , the problem is that when you take of from a stop you can floor it and their is no power , it takes about 5 to 10 seconds for the turbo to build 20PSI and then she takes off , the same when you go to pass someone you hold it to the floor and it will eventually build boost , the truck runs great other than that . i think the turbo is sticking , is that something that can be pulled apart and cleaned or is it a sealed unit any help would be greatly apretiated
Old Dec 18, 2006 | 09:24 AM
2006PSDSD's Avatar
2006PSDSD
Sounds like the turbo vanes are sticking. Try and get the truck out on the highway and hammer it hard to try and clear the soot from the vanes. These trucks,from what I have read, don't like to idle for extended periods of time because if this issue. You have to put your foot to te floor from time to time. Mine always seems to be on the floor
Old Dec 18, 2006 | 09:42 AM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 forum feepe
When you get a chance you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/303583-6-0l-diesel-tech-folder.html
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Old Dec 18, 2006 | 10:44 AM
BowTieHatr's Avatar
BowTieHatr
the best thing to do is put the truck in third gear and go play and romp the throttle as much as possible. more than likely, if it is that bad, then you wont be able to fix it because of rust on the unison ring. then again you could have other issues that are causing the boost issue.
Old Dec 18, 2006 | 11:12 AM
69cj's Avatar
69cj
If you have under 100,000 miles on it, get it to the dealer under warranty. If you pull the turbo apart then you will own it.
Old Dec 18, 2006 | 11:31 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If you have "chipped" the truck the warranty could be void. Also by not driving for 5 months I wonder if the fuel filter might be plugged.
Lead Head
Sep 14, 2016 03:14 PM
fordx4joe
Jul 17, 2016 03:19 PM
EPI-911
Sep 1, 2013 03:38 PM
beachbummin220
Nov 6, 2005 07:25 PM
southernturf
Sep 9, 2004 07:12 PM
