Bronco II Ford Bronco II
Tranny fluid type
Old Dec 17, 2006 | 09:38 PM
87broncoll's Avatar
87broncoll
Tranny fluid type
My Dad just changed my fluid.Advanced recommended Mercon V.Dad said mercon/dexron lll would work so thats what we used.Now my truck is seems to be winding out between gears.Its also hiccuping- Dad also replaced idle control valve.What type of fluid do you use?
Anyone had a their tranny rebuilt? My truck is dragging and hard shifting and thinking its time for a new one.How much will this set me back?
Also, do I need to reset computer after valve?
Old Dec 17, 2006 | 10:59 PM
mrshorty's Avatar
mrshorty
Which transmission? Most of the 5 speed transmissions recommend 80-90 gear lube. The M5OD (not very common in BII's) takes regular Mercon. The A4LD specifies regular Mercon. I don't think any of the stock transmissions for a BII called for Mercon V.
Old Dec 18, 2006 | 03:15 AM
kernel-panic's Avatar
kernel-panic
Could be that the vacuum modulator is bad, solenoids are bad, etc etc. Might want to also check for vacuum leaks and check to see if the kickdown linkage is intact. And no, neither the C-5 nor the A4LD called for Mercon V that I know of.
Old Dec 18, 2006 | 01:36 PM
OSin86's Avatar
OSin86
You can always go up on mercon ratings so there's nothing wrong with using V. Mercon V is actually the better fluid.
Old Dec 18, 2006 | 03:17 PM
youngfordguy's Avatar
youngfordguy
the a4ld wasn't a great tranny to begine with they had a short life span it just may be time to get it rebuilt
Old Dec 18, 2006 | 03:44 PM
kernel-panic
Also, not sure if the A4LDs had band adjustments or not? You can try checking the troubleshooting guides on http://www.autozone.com/repair_info.htm or get a haynes and/or chilton's manual and check that as well.
Old Jan 27, 2007 | 03:11 PM
BII Plow Truck's Avatar
BII Plow Truck
I use Amsoil in my A4LD and it shifts 500% better than stock. Plus it protects better for when I'm plowing snow here in Minnesota.
Pitcrw6
Jun 10, 2012 08:07 PM
Fordenthusiasts
Oct 25, 2010 06:06 PM
mxracer3276
Feb 27, 2009 01:29 PM
60RatRod
Dec 6, 2008 06:15 PM
pawpaw
Oil & Lubrication
31
Aug 31, 2008 09:42 AM
