Tps
Old Dec 17, 2006 | 08:47 PM
paulgc's Avatar
paulgc
Tps
My friend tell me that my throttle sensor is going out. Because about half way down on my pedal the truck shifts out and vibrates really bad. Then seems to run fine until it shifts down and I give it the fuel again. Are they anyway to test this sensor.
Old Dec 18, 2006 | 08:24 AM
tjbeggs's Avatar
tjbeggs
yes you need a graphing digital volt meter or a graphing scan tool to watch what the voltage is doing as you slowly push the pedal down. Most times it should set a code though if you have tps problems. Get it scanned for codes first and see if there is any thing in there.
