thermostat
Old Dec 16, 2006 | 10:04 PM
Bin Strokin's Avatar
Bin Strokin
thermostat
my mom has a 96 or 97 ford explorer with the V6 and it runs really cool so in the winter she cant get any heat. My dad and i both suspected the thermostat but their mechanic says it needs some special thermostat that costs around 300 bucks, is he full of it or is this true?
any feedback would appreciated
Old Dec 16, 2006 | 10:32 PM
kevin74656's Avatar
kevin74656
My Ex had this problem too, and it was the thermostat.
I hope that your parents misunderstood the mechanic. If he said that a thermostat costs $300, he is indeed full of it. The only thing "special" about the thermostat in my '96 with the 4 liter V6 is that it uses an o-ring around the circumference of the disk, instead of a paper gasket. It may have cost $15.
Did their mechanic just buy a new boat? He probably has pretty high payments....
Old Dec 16, 2006 | 10:56 PM
inFargo's Avatar
inFargo
Just replaced mine a couple of weeks ago. It seems that it goes out after 3 years. Not difficult to do, just a little messy draining the radiator. (lower passenger of the radiator, **** faces toward rear)
BTW, it isn't really an O-Ring, more of a o-ring like thing with a grove on the inside radius, at least on mine with a v-6. the ring fits around the thermostat. Usually comes with it in the same box. Make sure the little hole on the thermostat is oriented to the top position. it is for bleading off air, and to keep a little flow going through the thermostat so it can "sense" the temp.
Old Dec 17, 2006 | 06:18 AM
marragtop's Avatar
marragtop
You don't really need to drain the radiator. Remove the cap to relieve any pressure that may be in the system, and take the hose off the Tstat housing. You will lose some coolant, but not as much if you were to drain the radiator. Put the drain pan under the engine to capture what you do lose.
Old Dec 17, 2006 | 11:05 AM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Also make sure you use a motorcraft thermostat... most aftermarket brands tend to open too soon, reducing the heat.
Old Dec 17, 2006 | 11:11 AM
bdmcdonald's Avatar
bdmcdonald
Sounds like the thermostat to me. My 94 Ranger (4.0 V6) seemed to need a new one every two years. Makes a big difference in heat and performance. Just drain out a little coolant and remove the housing. Replace the thermostat and top off the coolant in the rad and the overflow tank. Now your warm....
Old Dec 17, 2006 | 12:46 PM
HomerWinzlow's Avatar
HomerWinzlow
Maybe it was the blend door broken? That would cause no heat.
Old Dec 17, 2006 | 12:47 PM
Bob Ayers's Avatar
Bob Ayers
Just another reason to use a Motorcraft thermostat, as suggested from MazdaRangerGuy. The Motorcraft will last longer than the after-market brands.
Old Dec 17, 2006 | 01:13 PM
Bin Strokin
thanks guys ill let them know, i figured the mechanic was tryin to pull a scam or somethin.
kyle j
Jan 2, 2025 10:50 AM
Craig46
1947 and Older Ford Trucks
Oct 26, 2015 07:32 PM
smittys5xs
1978 - 1996 Big Bronco
Nov 4, 2012 09:55 AM
kawika
Mar 19, 2006 02:56 PM
teamwizard
Aug 2, 2004 06:42 PM
