Sponsored by: Real Truck
Courtesy Lights
Old Dec 16, 2006 | 09:54 PM
Smitten's Avatar
Smitten
Courtesy Lights
Does anyone know what size the '05+ door courtesy lights are (ie 1/2, 3/4)?
Old Dec 16, 2006 | 11:22 PM
ReAX's Avatar
ReAX
1/2 or 3/4 what?
It should be the standard 194 bulb.
Old Dec 16, 2006 | 11:23 PM
ReAX's Avatar
ReAX
I believe most 194s are 3 watt, there another bulb with the same size and base that is 5 watts.
Old Dec 17, 2006 | 05:28 PM
Smitten's Avatar
Smitten
In the 05+, there is not a socket, or nothing in the doors..........Just wanted to know the socket size or if anyone has done an install.
Old Dec 17, 2006 | 08:37 PM
ReAX's Avatar
ReAX
Then you can fit just about any in there you wish. I would stick to the 1/4 turn 194 socket, you should be able to pick them up cheap locally. You will have to file the notches in if you want it to click in.
