Old Y Block Info Please !
I was directed to this sight from one of our members . I need help to figure out this motor. I just purchased a f600 and it does have a old y block in it because of the outside ribs in the valve covers . Well any ways This truck has 10 k on it the oils change stickers read 5860 & 3630 the ones I can Make out . Well any ways this motor has a autolite / Holley carb on it with a spin on oil filter . I was told these engines were built all the way to 1964. I thought it was kinda strange a truck with this amount of miles having a newer motor installed??? Any one out there Give me any hints . What Year this Motor IS ???
All Help Will be sure Greatfull .... Al
do you agree with this ? I've never been a ford nut but I know some of the old motrs .
Can you tell me what size this block is by this casting number ? Thanks for all your help. Al
I'm pretty sure that the F600's first model year, 1953, used a 239 flat-head v8. From 1954 up to the late 50's, the V8's were Y-blocks, either the Ford Y-block or the Lincoln style of Y-block. They started with a 239 y-block and also used 272 and 292's. The 272 had the letters ECG cast into the block next to the distributor and also under the alternator on the passenger side of the block. The 292 has its casting numbers over the oil filter. I don't know much about the Lincoln y-block but you can find out more at www.ford-y-block.com.
Sure do appriecate you reading it though , and trying to help .
I checked the block numbers and I Have a 1962-64 292 cid. After I found the right place to find everything.
Thanks Fer All your Help And Merry Christmas to every Body ! Al
