Quick door wiring question
Old Dec 16, 2006 | 07:02 PM
nickmobile67's Avatar
nickmobile67
I'm going to swap doors this weekend. Where's the plug for the door wiring? There's only a speaker wire I think. Thanks!
Old Dec 16, 2006 | 10:34 PM
TUFFY's Avatar
TUFFY
Under the kick pannels. That's where they were on mine anyway.
Old Dec 17, 2006 | 12:18 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes that's right, under the kick panels. and possibly behind the vent plastic if equipped with a vent.
You should be able to unplug it from where the rubber conduit hole is in the cab without removing the kick panel. but you may have to remove it anyway etc... such is life.
There were differences in speaker door wiring between 1980-1981s, and 1982-1986, models so you may have to use and swap the existing wiring in your existing doors with the donor doors depending on year. Or at least swap plugs.
hope this helps
Old Dec 17, 2006 | 08:12 AM
nickmobile67
Yep, my new door is gutted so I'll be switching everything. Thanks guys.
Old Dec 17, 2006 | 05:14 PM
nickmobile67
Got it done today. Paint is a perfect match! I only have a speaker in my door, so I just snuck the wire out and tucked it back into the new door.
Old Dec 18, 2006 | 07:58 PM
nickmobile67
All done. Check my gallery for pics. I must be doing something right, to find a perfect matching door in the boneyard. Just added the pinstripes and I was done.
