Roughf startup
Old Dec 23, 2006 | 10:01 AM
Reidicus's Avatar
Reidicus
I have the latest flash and still no difference in the start up. Even when its not that cold.
Question: Do they have to remove the head gaskets (and replace) to get to the fuel injectors?
Old Dec 23, 2006 | 11:43 AM
spikebee's Avatar
spikebee
Do your injectors buzz when you shut it down? If it still runs rough, then they're supposed to replace the injectors on the misfiring cylinders.
As far as injector replacement, they're right under the valve covers, so head gasket replacement is not required.
Old Dec 23, 2006 | 12:14 PM
Reidicus's Avatar
Reidicus
Thats good to know because I wouldnt want to buy another set of studs and hypermax gasket.
Is it easy to take the valve covers off?
Old Dec 23, 2006 | 12:20 PM
spikebee's Avatar
spikebee
Relative to anything else on the engine it is. Relative to the valve covers on a 1970 F100, it's a real PITA.
Boris2000
Computer Chips & Tuners
Mar 21, 2010 09:54 AM
stephenw
Exhaust Systems
Dec 30, 2002 11:58 AM
whittey
Nov 7, 2002 11:10 PM
dust3
Feb 9, 2002 07:31 PM
FTE Ken
Oct 15, 2000 07:44 PM
