Engine compartment painting
Old Dec 16, 2006 | 01:31 AM
Elderstarr's Avatar
Elderstarr
Hey guys, I need an expert opinion on using rustoleum's "hammered finish" paint to paint my firewall , rad support and inner fenders. I read a few posts and seen the outcomes of a couple projects and I like the idea of a textured finish. Still, I have a few questions...
Should I strip the factory paint to bare metal or can I get away with sanding with 200grit?
Is it better to rattle can it or brush it on?
Can I apply it in cold weather? As of now it is -10°c outside and the truck is enclosed in a coverall shelter, so should I invest in a heater, or should I wait for spring?
Is there a better textured finish I should be aware of?
Oh BTW the truck is a 1988 f250 with 6" lift, SAS, and soon to be a propane, turbocharged 351w. Currently the front end is dissasembled so prep work should be easy enough and I like the hammered finish because it hides imperfections, oil and dirt.
Thanks for you input.
Old Dec 18, 2006 | 10:36 AM
385seriesHemi's Avatar
385seriesHemi
Any paint should be applied in my opinion 50 degrees (+10 degrees celcius) or higher, if you can't get it that warm id only go as low as 45 degrees (+7 or so degrees celcius) but with a heat gun if you can't wait. What I would do is wait until a warmer dry spring day when you don't have to worry bout heating up an area and you can take you time.
Old Dec 19, 2006 | 12:49 PM
Elderstarr's Avatar
Elderstarr
Most paints I've used reccomend that it needs to be applied in temperatures above 15°C, I just have no experience with rustoleum so I figured I should ask. However, the cold weather should not be a problem anymore since my friend has allowed me to paint in his heated garage. If I should spray, I will throw plastic up on the walls.
So, has anyone brushed on rustoleum paint before? Does it leave brush marks?
Thanks for you help.
Old Dec 25, 2006 | 08:04 PM
dcunningham's Avatar
dcunningham
no it don't leave brush marks.
Old Dec 26, 2006 | 07:37 PM
Elderstarr's Avatar
Elderstarr
Great, thanks. Now is it better to sand down to bare metal, prime and paint, or can I get away with scuffing with 200grit and painting?
Old Dec 27, 2006 | 06:48 PM
dcunningham
scuffing with 200grit and painting will be fine
