tranny interchange
Old Dec 15, 2006 | 09:24 PM
momsvan89's Avatar
momsvan89
tranny interchange
Hi everyone,
New here, I hope someone can answer my question. I have a friend with a 62 Ford Fairlane with a 221 v8 and a two speed transmission. He's had an ongoing problem with the transmission leaking from several places, front pump, pan, servo cover on the side. It's been resealed a couple times, but it still continues to leak. Now he's thinking of a different trans, possibly a three speed c-4. The question is, will a c-4 bolt up to the 221 v8? Is there any specific year he needs to look for? Any help at all would be greatly appreciated.
Old Dec 16, 2006 | 12:33 AM
85e150's Avatar
85e150
221 of that year would use the 5 bolt bell. A 6 bolt bell replaced that in '65.
These folks sell trannys, and have a way to check on bells.
http://www.tciauto.com/Products/TechInfo/c4_bellhousings.asp
My guess is a c4 from a 63 or 64 Falcon or Fairlane. These should be the correct length. Early '65s would be a good bet. Look for cars with 260s. Only early 289s used this pattern.
Old Dec 16, 2006 | 04:20 PM
momsvan89's Avatar
momsvan89
Thanks for the reply. I will give them a shout. I'm thinking that a 63 or 64 c4 will not be easy to come by.
Old Dec 16, 2006 | 11:19 PM
hadman50's Avatar
hadman50
Once upon a time I had a 64 Fairlane with a 289 & c-4. The bell housings would swap out, the trannys from 63 to 68 should interchange. So the exact year of trannsmission shouldn't make that much of a diffrence if you can change out to the 5 bolt bell housing.
Old Dec 19, 2006 | 05:46 PM
momsvan89's Avatar
momsvan89
Ok, if I understand this right, I can use the bellhousing from the two speed tranny currently in the car and use it on a c-4 from 63 to 68. What about trannies from 69 and up? Am I correct in this? HELP!
Old Dec 19, 2006 | 10:08 PM
85e150's Avatar
85e150
Hhhmm. Not sure about that. Doubt it.
What I was suggesting is to find a C4 with the 5 bolt bell that your engine has, or to find a C4 bell and then bolt up whatever C4 you can find.
Old Dec 20, 2006 | 06:26 AM
stuart1's Avatar
stuart1
Wrong.
The 2 speed transmission case and housing are all one part.
Old Dec 20, 2006 | 07:41 PM
momsvan89's Avatar
momsvan89
Ok. So I need at least a bell housing from a 62(?) 63 or 64 c-4 with a 5 bolt pattern and any c-4 up to 68? That is going to be like finding a needle in a haystack. Chances of finding a 5 bolt bell housing/tranny in this area is going to be impossible. Maybe I'll just try to talk my friend into swapping in a 5.0 from a Mustang or something and go with the full retro-mod thing complete with fuel injection.
Old Dec 21, 2006 | 05:27 AM
LEVEL10's Avatar
LEVEL10
give us a call we can help you out. and as to the car.it's a rare classic! stay stock and numbers matching it's worth more money that way. as to leaking some thing tells me you have some thing warped or miss installed or more likely a worn bushing causeing the unit to seem it has a leak.
we have 2 of the best builders here that have been around long enough to know that unit when it was new and surely know how to make it stop leaking.
Old Dec 21, 2006 | 06:15 PM
momsvan89's Avatar
momsvan89
A rare classic I will agree with, but this car will never be a 68 Shelby GT500KR. It's a 62 Fairlane 4 door with a 221 V8 and a 2 speed transmission. Hardly big money. The car is straight, but needs a paint job (faded red right now). The interior is about perfect on it. I've replaced the front and rear springs and he had another shop do a head job. He's not too concerned about keepeing it stock (we've added some aftermarket gauges and just recently put in a pertronix electronic ignition conversion), he just wants it reliable and leak free. Thanks for all your help. I will pass this information on to him and he can decide what he wants to do.
