Rear-end info
Old Oct 28, 2001 | 09:05 PM
OneUgly58's Avatar
OneUgly58
Rear-end info
Old Oct 29, 2001 | 04:41 PM
51f1's Avatar
51f1
Rear-end info
[font size="1" color="#FF0000"]LAST EDITED ON 29-Oct-01 AT 05:42 PM (EST)[/font][p]Found more info on the mystery rear-end in my 1951 F-1. I sure appreciate y'alls help so far.I beleive it must be stock. I found a patent # 201818? (couldn't make out the last digit) on the housing. #2018188 is a rear end patented in 1935 by Joseph E. Padgett and Robert P. Lewis. There is also a patent #1868818 on my housing. This # is for a U-joint also patented in the 1930's. My rear end has 10 studs threaded thru the rear cover into the housing(no nuts), A drain on the bottom approx. 1" dia. and a peep hole on the passenger side of the rear cover on the same plane as the axle and drive shaft approx. 1" in dia. Also after much scraping I DID find a tag. However I can't match it to any charts that I have found. It reads:W4712 A large "W" on your left followed by the "47" over the "12", similar to a fraction. Also there is number "12" forged upside down into the front of the center section and besides the 2 patent numbers, which are on the rear of the center section, there is 18419 (not positive on the 9) also on the rear of the center section but this isn't noted as "US PAT".
I sure hope someone can help me make heads or tails of this--
Thanks in advance!
Erik in St. Louis
'51 F-1 daily driver
Old Oct 29, 2001 | 06:56 PM
barry's Avatar
barry
Rear-end info
According to your description, and looking in my 48-56 parts book, you have the stock rear that came in 51-52 F-1's. There's a pic of the rear cover and it has the plug where you describe and the lower drain plug. The parts book shows either a 3.92 or 4.72 ratios for it. If you still have the I.D. or rating plate on the glove box door, on the lower line, it has the ratio on it. You should get yourself a shop manual if you don't already have one. They're all over Ebay from $5.00 and up. Best investment you'd ever make.
Old Oct 29, 2001 | 09:07 PM
51f1's Avatar
51f1
Rear-end info
I appreciate you checking it out. According to the plate it's 3.92. Do you know what "kind" of rear it is Dana, etc?
Thanks again for your help-
Erik in St. Louis
Old Oct 29, 2001 | 09:47 PM
johann5's Avatar
johann5
Rear-end info
According to my book, you have a '50 stock F-1 rear end. It is the only one with a 3.92:1 ratio. The 11 and 47 are numbers of teeth. (47/11=3.9166) Also, about all that praise of Ford rear ends being prefered for racers because of the extra support of the pinion...sorry, according to my picture, this rear end doesn't have an additional bearing. 8" vs. 9" - still don't know.
You have my curiosity up about my rear end, but I will post that as another message.
Johann
Old Oct 30, 2001 | 07:49 AM
barry's Avatar
barry
Rear-end info
Yes, it's a Dana (Spicer ) rear end. Chances are, the original rear could have been changed after it blew up or I'm finding the factory books have errors and info was not included. The 48-56 parts books are full of errors. The earlier 48-55 series books are much better for accuracy.
Old Oct 30, 2001 | 06:19 PM
51f1's Avatar
51f1
Rear-end info
Barry, thanks for the help--I owe ya! I started digging around about this because I have an '88 Cougar X-R7 that I'm going to start "raping" for my truck.
Thanks again !!
Erik in St. Louis
Old Oct 30, 2001 | 06:32 PM
51f1's Avatar
51f1
Rear-end info
Johann5- Thanks for the help!!
Erik in St. Louis
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
