Torque Wrench
Old Dec 15, 2006 | 07:23 PM
natewoz's Avatar
natewoz
Torque Wrench
I'm looking for a 100 inch-lbs or less torque wrench for measuring preload when I regear my 8.8. What brands do you guys use and where do you purchase from? Thanks
Old Dec 15, 2006 | 09:30 PM
wickymustang's Avatar
wickymustang
I use my snap-on inch-lb torque wrench. It has the dial on it and you can either set the needle to zero and then torque and watch the needle. Or you can set the needle to what the torque setting is and then go til it comes around to the pin on the wrench. Fairly cheap and accurate enough for the work you are talking about.
