replacing a seal....
Old Dec 14, 2006 | 10:19 AM
Sn0wMan's Avatar
Sn0wMan
Rear of the tcase on my 94 f150, where rear driveshaft goes in, the outter seal must have gotten tore up from dirt, its leakin some fluid. I bought the replacement (which i hope is the right one) and its called the output tcase seal. My thoughts are to take out the driveshaft and buzz off the yoke with an air gun, then just pull out the old one and slide in the new one? Really need some advice on this one, would be much appreciated. Dont wanna hurt my baby lol
Old Dec 14, 2006 | 01:20 PM
385seriesHemi's Avatar
385seriesHemi
You have the procedure correct just match the seals b4 you install. All though when you take the old seal out it probably isnt going to be easy from corrosion n such keeping it in. Just take your time thats all.
Old Dec 14, 2006 | 05:17 PM
Sn0wMan's Avatar
Sn0wMan
Thank you very much!!! Needed some advice to make sure i was right.
Old Dec 14, 2006 | 05:23 PM
385seriesHemi
If you have ever done a seal on a Drive pinion on a differential its basically like that since you have to take the yoke out ya kno. If you cant get it out by prying on the lip of the seal just take a hammer and a screw driver and collapse the seal and just pull it out.
Old Dec 15, 2006 | 04:54 AM
stuart1's Avatar
stuart1
It is best to clean the surrounding area first.
Then when you remove the old seal there is less chance of letting any junk in.
Old Dec 15, 2006 | 09:33 PM
wickymustang's Avatar
wickymustang
As the others have said it is much like a pinion seal on a diff, just make sure it is clean around it and that you take your time. Double check the seal to be right and make sure you don't get anything in the t-case while working (dirt, metal flakes, ect) Also, take this time to refill the t-case with fresh fluid.
Nothing Special
May 5, 2013 09:14 PM
ssrider
2004 - 2008 F150
Dec 8, 2011 10:35 AM
JeffMc202
May 6, 2009 08:52 AM
lmadore
26
Nov 8, 2004 01:33 PM
