View Poll Results: Who is going to win the superbowl?
Jacksonville
0%
San Fransisco
0%
Cincinatti
0%
New Orleans
100.00%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
help with bigger tires...
Old Dec 15, 2006 | 06:27 PM
DngrRngr2499's Avatar
DngrRngr2499
right now i have a 2005 ranger...edge...sweet lil truck...but im looking to get new tires on it....what is the biggest size i can get on them....without having to make drastic changes to the truck...i.e.: lifts or cutting out fenderwells
Old Dec 15, 2006 | 06:42 PM
Bob Ayers's Avatar
Bob Ayers
Why bigger tires? Unless you change your dif. ratios, bigger tires will give you less performance, and less MPG..........Unless you just want to look at your
truck.
Old Dec 15, 2006 | 06:49 PM
DngrRngr2499
well...i would like to add both height and look to the truck...i mena i could do that by adding spacers...which i will at some point...i have gone off roading with it once and it was a blast...didnt know how well a 2x4 did in the mudd when you kind of know what ur doing...i feel that i would do better if i had bigger tires
Old Dec 15, 2006 | 06:57 PM
Bob Ayers's Avatar
Bob Ayers
You will have to determine what you do the most, on or off road. If you do more on road, then there are more disadvantages than advantages of bigger tires.
Old Dec 15, 2006 | 07:00 PM
DngrRngr2499
well...say if i buy just tires(and rims) for just offroading...what would the best bet be?
Old Dec 15, 2006 | 07:02 PM
wendell borror's Avatar
wendell borror
If you have an edge, you have the torsion bar front suspension. You can crank the torsion bars a little to level the truck and run up to a 31" tire. If you have factory 4:10's, it won't be to bad. A good limited slip diff would help a lot, like a tru-tac. You may be better off just getting a 4x4 and be done with it, if you really like offroading. Its a fun hobby. Your allways be some what limited with a 2 wheel drive, compared where you could go with a 4x4.
Old Dec 15, 2006 | 07:06 PM
DngrRngr2499
oh trust me...i know...i mean im looking for a beater right now...i was just thinking of looks. even still i have 15's on there right now...id love to have a lil bit bigger tire...i know the disadvantges like poor gas mileage and bad turning radius, etc...but you know...
Old Dec 15, 2006 | 07:07 PM
Bob Ayers's Avatar
Bob Ayers
Stock tires for on road, and a larger set of rims/tires for off road would solve the problem with bigger tires on road. You will just have to decide if the investment of a second set of rims/tires will be worth it, especially since it's a 2WD. If your 2WD is your only transportation, you always risk breaking something when you go off road, so you will have to determine if you can afford something like this happening. If you enjoy off roading, I would suggest buying a "beater" 4wd for off roading.....
Old Dec 15, 2006 | 07:11 PM
DngrRngr2499
so...stick with looking for a beater...i can do that...would u recommend spacers in the springs to help lift the truck...i realize the stiffer suspension as the outcome...any other disadvantages?
Old Dec 15, 2006 | 07:16 PM
Bob Ayers's Avatar
Bob Ayers
Any time you raise a vehicle, you are raising the center of gravity, which makes it unstable at higher speeds, and more sensitive to side-winds. That,
along with poorer handling, much rougher ride, and mods like this drastically reduce the value of your truck.
Old Dec 15, 2006 | 07:20 PM
wendell borror
You shouldn't have springs, edge 2 wheel drives had torsion bars like a 4x4 in 05. Spacers won't work and lift kits are outrages for this set up. Check to see if you have front springs, if not, you'll have to crank the t-bars or get an expensive lift kit. I had an allignment shop crank my t-bars and reallign the front end, it cost me 55.00. Alot of guys crank thier own for free, but you would still need the allignment. "Yes", it's very easy to tear stuff up offroad, be carefull.
DngrRngr2499
understandable...i'd rather have spacers then a body lift...then again a suspension lift would be better, just costs a bit more...
Old Dec 15, 2006 | 07:24 PM
DngrRngr2499
wow...i just looked under my truck and realized i didnt have front springs....totla shock to me...i thought i had them...where do i find longer torsion bars? and you said they cost 55.00? i realize that that price where u live...
Old Dec 15, 2006 | 07:28 PM
Bob Ayers's Avatar
Bob Ayers
What Wendell was describing was adjusting your present torsion bars, not replacing them. As Wendell pointed out, you will have to get a front end alignment if you do this.
Old Dec 15, 2006 | 07:31 PM
DngrRngr2499
if i take it to someone professional .... who would it be and if not how would you do it?
