MANUAL tranny swap
Old Dec 15, 2006 | 12:18 PM
CheaperJeeper's Avatar
CheaperJeeper
MANUAL tranny swap
There have been a lot of threads lately about swapping automatics, so I thought I'd start one to ask a couple of questions about manual trannys.
The 86 F250 4x4 I just bought has a pretty serious growl in the tranny in 1st-3rd gears but not in 4th. From that symptom and what I've read around here I'm thinking that the bushings on the counter-shaft (a.k.a. jack-shaft or lay-shaft) are toast.
Soooooo, I'm looking at either tearing it down and replacing the bushings, swapping in another used T-19, OR attempting to upgrade the tranny.
So, I'm wondering, how hard would it be to install the 5-speed from a 1990 F250 7.3L? Will it mate to my t-case? Or would I have to get the t-case off the donor as well?
Anybody know what the ratios would be in a 5-speed from a 1990? I'm assuming 5th would be an overdrive.....
Old Dec 15, 2006 | 07:15 PM
Mr. Bob's Avatar
Mr. Bob
I swaped a ZF gas in behing my 351W in my bronco... it was an AMAZING upgrade... I have a T19 with 3.55s and 315/75/R16s and still find my self looking for 5th almost every time I drive it...
Your T case will bolt up to the ZF...
The only issue I ran into in my swap was the ZF was 2.5" longer than an AOD... because of my lift this was perfect for the rear as it gave me more spline length in the drive shaft to work with, but caused me to need my front drive shaft to be lengthened...
You will also need to figure out what clutch setup you are going to run....
Old Dec 15, 2006 | 10:49 PM
catfish101's Avatar
catfish101
If you are putting the ZF behind a 6.9. You will have to run a damped 7.3 disk with the 6.9 pressure plate and you will have to build up the fork for the bearing. The ZF has a deeper flywheel housing because of the dual mass flywheel. You have to use a 7.3 disk because the input shaft won't work on a 6.9 disk. The ZF is different then the Borg Warners.
I was told there is a kit to make this conversion now but I would say it is expensive. I think it has the whole 9 yards. Flywheel,clutch,fork ect.
My brother and I put a 6.9 in a later model truck a few years ago and there wasn't a kit then. All we were told is that it wouldn't work. Well it does.
Hope this helps.
Old Dec 16, 2006 | 01:19 PM
CheaperJeeper
So if I'm reading/understanding you guys right, I'd have to go to a dual-mass flywheel to do this conversion? If that's the case forget it. Too expensive and I've read about too many issues with them. I suppose the ZF is the only 5-speed that will fit, eh?
Old Dec 16, 2006 | 06:12 PM
catfish101's Avatar
catfish101
No. You use your 6.9 flywheel and pressure plate. You have to use a 7.3 dampened disk because of the ZF input shaft. You will have to do some fork modification to make up for the flywheel housing depth.
Old Dec 16, 2006 | 09:15 PM
CheaperJeeper
Ohhh, OK, a dampened clutch disk. That sounds much better.
Modifying the TOB fork doesn't sound too bad. Anything else?
Old Dec 17, 2006 | 07:16 AM
tjc transport's Avatar
tjc transport
i ain't rite
yea, you can use the ZF 5 speed, and a LUK clutch assembly for the ZF. the LUK setup is around $600 complete. flywheel, disc, pressure plate, throw out bearing, everything you need to take the dm crap and make a boat anchor out of it.
Old Dec 17, 2006 | 02:06 PM
Spectramac's Avatar
Spectramac
Going back to the 4 spd...
It's my guess that you just need an input bearing. That usually makes them noisey in the low gears and quiet in 4th cuz it goes straight down the mainshaft instead of side loading the front bearing going thru the cluster gear. That would be a pretty CHEEP fix in my book. The only strange part is that you mention 1st and 3rd, what does 2nd do?
Old Dec 17, 2006 | 02:12 PM
CheaperJeeper
Sounds good to me - I'd love it if I could replace just one bearing instead of the whole tranny. Especially if it can be donew without tearing the whole tranny apart
When I wrote "1st-3rd" I meant 1st through 3rd (including 2nd), not just 1st & 3rd. So yeah, its noisy in 2nd too - 4th is the only quiet gear right now....
Old Dec 17, 2006 | 02:46 PM
Spectramac's Avatar
Spectramac
Oh, that makes more sense then.
The input bearing is usually the first to go, they spin all the time at engine speed and are the the furthest from the oil. With that turbo'd engine the oil's probably always jammed up in the back of the case anyway.
Old Dec 17, 2006 | 03:17 PM
Dave7.3's Avatar
Dave7.3
Would it be a good idea to replace the DMF in my truck? It already has a ZF5 but has a noisy throw out bearing. Shop tells me it would be a good idea to do a full replacement but the clutch seems fine. Dave S also informend me that the growl within the 1100 rpm range is my DMF out of wack so might it be a good move to upgrade with that LUK setup? Also, what are the pros and cons of the swap?
Old Dec 17, 2006 | 04:00 PM
tjc transport
i ain't rite
the pros of the LUK setup is that it is a much better unit than the DM setup, the flywheel is one piece instead of two, and the complete setup can be bought for less than a DM flywheel alone costs.
and the cons of the swap are the same. the LUK is better, and costs less. so you will never hear a ford dealer make mention of it.
Old Dec 17, 2006 | 05:44 PM
CheaperJeeper
How hard is that bearing to replace Malcom? Once you have the tranny out, how far do you have to tear it apart to R&R that bearing?
Old Dec 17, 2006 | 07:02 PM
Dave7.3's Avatar
Dave7.3
Alright, sounds like a good deal. Are these available in kits? I saw one on ebay but its just the clutch I believe for about $175. I will keep looking but if you can find where I can get the complete kit, that would help very much. Figure I might as well get it squared away while I'm in there...
-Dave
Old Dec 17, 2006 | 08:31 PM
harleyjohn45's Avatar
harleyjohn45
i replaced my clutch and flywheel completely for 250.00. the clutch that came out of my 91 7.3 was also a one piece flywheel. i bought the entire setup at napa. it was made in china and worked like a charm. my clutch was making noise, it was not slipping. i think the flywheel was not true.
