Clutch Pedal Pressure Problem
In August I finally got the truck back together and running. I rebuild the engine, machined the flywheel, and put a new Centerforce II clutch, pressure plate, and throwout bearing on it. I also put a new clutch fork on it because it was one of the "lost" parts. I happened to have the very original fork (which had been replaced years ago because the adjusting rod pocket had a hole worn in it). The fork i put in looked just like the original. The aluminum pivot block looked good.
After reassembling everything I found that the clutch behaved very strangely. As you stepped on the clutch there was the normal freeplay, then consistant and reasonable pressure until about half-way. You could tell that was where the clutch diaphram released and then the pedal was extremely soft for the remainder of the travel to the floor. THe problem lies with letting the pedal up. There is very little pressure so you have you have a light foot to let up the pedal. Now when you get to the stiff part, it gets so stiff, so fast, that you can't control it and you basically pop the clutch. This is very frustrating behavior.
The first thing I did was to rebuild all the linkage. I took the pedal assembly out from under the dash, replaced the bushings, regreased, and reassembled. I replaced the plastic bushings on the clutch rod from the pedal to the equalizer bar also. I also replaced the bushings and felt washers on the equalizer bar. These changes made no difference. At this point I thought that maybe I had a bad pressure plate. When my dad sold the truck, he had a Centerforce I in it that was perfectly smooth with a progressive pedal feel - it felt like every other clutch i've ever driven.
I have checked and double checked all part numbers.
I pulled the transmission and replaced the clutch with a new Centerforce I. I reassembled everything, and it felt exactly the same. At this point, I bought a new equalizer bar because mine had a little bit of play in the block that pushed on the adjustment rod. No difference.
At this point, I'm out of ideas, but I know for sure that I'm not happy with the clutch. The problem is that I'm not sure where the problem lies. I don't want to put a third clutch in it and find that it still doesn't fix the problem.
Any ideas?
All in all, it is exactly the same. I had someone help me work the clutch and watch the linkage and everything looks fine. There is no flexing in the linkage, no slop... Everything looks perfect.
The only think we can come up with is that what I am experiencing is just how the Valeo clutch is going to be. I'm just about to throw out the second centerforce and just get a remanufactured Ford.
