Spark check using inductive timing light?
Old Dec 14, 2006 | 12:46 PM
daszanto's Avatar
daszanto
Mom-In-Law's car won't start. Would it not be easier to check for a spark using an inductive timing light on each wire instead of pulling plugs and grounding them? Car is 20 miles away, don't even know what engine is in it. She says it turns over, but won't start. Plan to first check ignition, then fuel system(new fuel filter comes 1st). Thanks, Dave
Old Dec 14, 2006 | 03:09 PM
Franklin2's Avatar
Franklin2
You can do that, though it will not give you any spark quality info. And you really only need to check one or two usually.
Old Dec 14, 2006 | 04:03 PM
daszanto's Avatar
daszanto
Franklin2, thank you for your reply.
