Is it necessary? I noticed on guzzle's instructions he put filter restrictor in the end of the filter. also what size pipe was used to connect the filter to the intake tube?
No, the AIT sensor needs to be left intact but many will zip-tie it to the master cylinder or somewhere close to the filter. The filter-minder is also not necessary but SpringerPop came up with the idea to plug it into the end of the filter and it simply serves as a little more protection if the filter gets prematurely clogged.
I used a piece of 4" exhaust tubing to connect the filter to the intake hose.
Well guys, I ordered one of marks 5 inch exhaust systems with no muffler. I just got it in today man that thing is huge. I plan on installing it tonight if I have time. I can't wait to hear what it sounds like and how it looks with that monster exhaust.
Thanks rad, i already got the 6637 filter mod on my truck. Curious to see how much it helps pick up the truck and mpg. I don't have any programmers on it right now. its stock
How do you like your 5" exhaust? Did you install a muffler? Drone?
I'm considering 5" or 4" duals....or maybe a 4" if I lose power in the low end.
